voila les valeurs au a 3000trs et au ralenti
a 3400trs:
Battery Voltage,14.2 V
Ignition Status,On 12V
APP at Idle Position (Accelerator Pedal Position),Inactive
APP Sensor 1 (Accelerator Pedal Position),1.67 V
APP Sensor 2 (Accelerator Pedal Position),0.83 V
Calculated Pedal Position,23 %
Barometric Pressure,102 kPa
Barometric Pressure,4.18 V
Boost Pressure Command,132 kPa
Boost Pressure,135 kPa
Boost Pressure,2.15 V
Mass Air Flow Sensor,740 mg/strk
Mass Air Flow Sensor,3.67 V
Intake Air Temperature,59 °C
Intake Air Temperature,1.08 V
Coolant Temperature,68 °C
Coolant Temperature,1.55 V
Engine Oil Temperature,45 °C
Engine Oil Temperature,3.53 V
Fuel Temperature,27 °C
Brake Switch 1,Inactive
Brake Switch 2,Inactive 12V
Desired Engine Idle Speed,800 RPM
Engine Speed,3 364 RPM
Injection Pump Speed,1 680.40 RPM
Desired Injection Start,9.9 °CA
Actual Injection Start,10.1 °CA
Actual Injection Quantity,7.3 mg/strk
A/C Information Switch,Inactive
A/C Relay (Air Conditioning),Inactive
A/C Load Signal (Air Conditioning),14 %
A/C Pressure (Air Conditioning),366 kPa
EGR Position Command (Exhaust- Gas Recirculation),100 %
EGR Pulse Ratio (Exhaust Gas Recirculation),95 %
Pulse Ratio Throttle Control Solenoid Valve,5 %
Throttle Position Sensor,5.00 V
Throttle Position,100 %
Pulse Ratio Boost Pressure Solenoid Valve,23 %
Swirl Level Control Solenoid Valve Pulse Ratio,4 %
Outside Temperature Sensor_,16 °C
Outside Temperature Sensor_,2.11 V
Glow Time Relay,Active 0V
Diagnosis Glow Time Relay,Inactive
Glow Time Telltale,Off
Malfunction Indicator (MI),Off
Service Vehicle Soon (SVS) Indicator,On
Vehicle Speed,0 km/h
Clutch Switch,Inactive
Park/Neutral Switch,P - N 0V
Cruise Control Tip Switch,Inactive
Vehicle Speed in Cruise Control Range,Inactive
EGR Feedback (Exhaust Gas Recirculation),87 %
et au ralenti:
Battery Voltage,14.1 V
APP at Idle Position (Accelerator Pedal Position),Active
APP Sensor 1 (Accelerator Pedal Position),0.97 V
APP Sensor 2 (Accelerator Pedal Position),0.49 V
Calculated Pedal Position,0 %
Barometric Pressure,4.19 V
Boost Pressure Command,98 kPa
Boost Pressure,99 kPa
Boost Pressure,1.61 V
Mass Air Flow Sensor,295 mg/strk
Mass Air Flow Sensor,1.46 V
Intake Air Temperature,56 °C
Intake Air Temperature,1.20 V
Coolant Temperature,71 °C
Coolant Temperature,1.47 V
Engine Oil Temperature,49 °C
Engine Oil Temperature,3.39 V
Engine Speed,801 RPM
Injection Pump Speed,399.98 RPM
Desired Injection Start,3.0 °CA
Actual Injection Start,3.0 °CA
Actual Injection Quantity,4.2 mg/strk
EGR Position Command (Exhaust- Gas Recirculation),75 %
EGR Pulse Ratio (Exhaust Gas Recirculation),73 %
Pulse Ratio Boost Pressure Solenoid Valve,38 %
Outside Temperature Sensor_,15 °C
Outside Temperature Sensor_,2.15 V
