J'ai mais en la langue de shakespeare
Et le reste par MP ou mail
11.2 Exploded view of the throttle body/injector
housing assembly - 1.4 and 1.6 litre models
1 Air filter seal
2 Injection valve
3 Injection valve holder
4 Upper O-ring
5 Lower O-ring
6 Upper housing
7 Seal
8 Fuel inlet connector
9 Fuel inlet seal
10 Fuel return connector
11 Fuel pressure regulator diaphragm
12 Fuel pressure regulator spring
13 Fuel pressure regulator spring seat
14 Fuel pressure regulator cover
15 Connecting cable grommet
16 Throttle body
17 Potentiometer (throttle valve)
18 Idle air stepper motor
19 O-ring
20 Idle adjustment screw
21 Idle adjustment screw spring
22 Cap
23 Vacuum connections flange
24 Vacuum connections flange seal
25 Injector housing- inlet manifold seal
