09 novembre 2026 à 02:19:00
Auteur Sujet: résulat opcom.  (Lu 5218 fois)
Hors ligne lorie
  • Date de 1ère mise en circulation: 27/05 /005
  • Motorisation: 2.2 DTI 117 CH disney pack elegance selon la carte grise
  • Véhicule: Opel zafira 330 000 klm
résulat opcom.
« le: 18 août 2012 à 19:26:12 »
bonjour tout je monde voila j'ai reçu mon  opcom est ce que quelqu’un pourra m'aider a comprendre si il y a un défaut et si mon diagnostic est bon
OP-COM 100219a - PC based diagnostic tool
Date and time>,18/08/2012. 19:851
Workshop information:
hkj
Selected model>,2005,Zafira,Engine,Y 22 DTR
Control Unit:
Keyword #1: EF
Keyword #2: 8F
Normal timing parameter set.
VIN: LORIE7500019874585
vehicleManufacturerECUHardwareNumber 55352863
systemSupplierECUHardwareNumber: BOSCH010000001401
systemSupplierECUHardwareVersionNumber: 0000
systemSupplierECUSoftwareNumber: VMCM1F20_S
systemSupplierECUSoftwareVersionNumber: 0CE5
exhaustRegulationOrTypeApprovalNumber: B03030
systemNameOrEngineType:  Y22DTR
RepairShopCodeOrTesterSerialNumber:  Not programmed
ProgrammingDate:  FFFFFFFF
Identifier: 1414
VehicleManufacturerSpecific: 0470504225
Measuring blocks information:
Battery Voltage,13.6 V
Ignition Status,On  12V
APP at Idle Position (Accelerator Pedal Position),Active
APP Sensor 1 (Accelerator Pedal Position),0.97 V
APP Sensor 2 (Accelerator Pedal Position),0.48 V
Calculated Pedal Position,0 %
Barometric Pressure,94 kPa
Barometric Pressure,3.71 V
Boost Pressure Command,98 kPa
Boost Pressure,95 kPa
Boost Pressure,1.54 V
Mass Air Flow Sensor,464 mg/strk
Mass Air Flow Sensor,2.18 V
Intake Air Temperature,60 °C
Intake Air Temperature,1.07 V
Coolant Temperature,89 °C
Coolant Temperature,0.98 V
Engine Oil Temperature,86 °C
Engine Oil Temperature,2.00 V
Fuel Temperature,53 °C
Brake Switch 1,Inactive
Brake Switch 2,Inactive 12V
Desired Engine Idle Speed,800 RPM
Engine Speed,800 RPM
Injection Pump Speed,400.23 RPM
Desired Injection Start,3.1 °CA
Actual Injection Start,3.0 °CA
Actual Injection Quantity,3.4 mg/strk
A/C Information Switch,Inactive
A/C Relay (Air Conditioning),Inactive
A/C Load Signal (Air Conditioning),33 %
A/C Pressure (Air Conditioning),1 026 kPa
EGR Valve (Exhaust-Gas Recirculation),Inactive ((( pourquoi elle est inactive c'est la venne EGR?)))
EGR Position Command (Exhaust- Gas Recirculation),100 %
EGR Pulse Ratio (Exhaust Gas Recirculation),95 %
EGR Feedback (Exhaust Gas Recirculation),Okay
Pulse Ratio Boost Pressure Solenoid Valve,39 %
Swirl Level Control Solenoid Valve Pulse Ratio,4 %
Pulse Ratio Throttle Control Solenoid Valve,5 %
Outside Temperature Sensor_,29 °C
Outside Temperature Sensor_,1.47 V
Glow Time Relay,Active 0V
Diagnosis Glow Time Relay,Inactive
Glow Time Telltale,Off
Malfunction Indicator (MI),Off
Service Vehicle Soon (SVS) Indicator,On
Vehicle Speed,0 km/h
Clutch Switch,Inactive
Park/Neutral Switch,P - N  0V
Cruise Control Tip Switch,Invalid
Vehicle Speed in Cruise Control Range,Inactive
ZAFIRA what else!!!
Re : résulat opcom.
« Réponse #1 le: 19 août 2012 à 10:30:02 »
Apparemment le défaut n'est plus présent.
Celui ci correspond à un problème au régulateur du pulseur de ventilation.
Est ce que le pulseur fonctionne?
Hors ligne lorie
Re : résulat opcom.
« Réponse #2 le: 19 août 2012 à 19:06:38 »
bonjour , me voila aujourd’hui encore une fois avec une clé orange. en effet je suis parti pour faire l'autoroute et j'ai fait 150 klm  normal . amis en revenant  ma voiture est revenu lourde et elle dépasse pas 3000 tour  et dépasse pas 110 klm a l'heure. en arrivant chez moi j'ai pas arrêté le moteur et j'ai fait une analyse opcom
voila le résultat
:OP-COM 100219a - PC based diagnostic tool
hkj
OP-COM - KW2000 Communication Window> 2005|Zafira|Engine|Y 22 DTR
Keyword #1: EF
Keyword #2: 8F
VIN: xxxxxxxxxxxxxxx
Identifier: 1414
Total number of fault codes: 2
P1540 - Air Condition PWM-Signal invalid
 (0D) - Not present
P0234 - Boost Pressure Control Circuit Positive Deviation
 (03) - Present
ZAFIRA what else!!!
Re : résulat opcom.
« Réponse #3 le: 19 août 2012 à 20:48:08 »
Hors ligne vectrarecord
  • Véhicule: bmw 325 tds
Re : résulat opcom.
« Réponse #4 le: 19 août 2012 à 21:04:04 »
J ai eu ce code aussi. Problème de turbo :bah
ose devenir ce que tu es
Hors ligne lorie
Re : Re : résulat opcom.
« Réponse #5 le: 19 août 2012 à 21:18:58 »
bonjour et puis tu as changé le turbo???
car moi c'est que elle me fait le coup deux fois dans un mois et après plus rien et après ça revient.
ZAFIRA what else!!!
Re : Re : Re : résulat opcom.
« Réponse #6 le: 19 août 2012 à 21:22:45 »
Regarde les petits tuyaux derrière le débitmètre
« Réponse #7 le: 19 août 2012 à 21:24:28 »
non j ai rien fait, le voyant s allume pas souvent depuis que le turbo et le capteur de pression ont été nettoyé.
Y a trois semaine on a changé une durite de turbo et depuis plus rien... Espérons que ce soit que ça
